Licence with 0kb??
Posted: Tue Aug 18, 2026 5:33 pm
by onix05
MTS 1200S 2015: no registration
Hi, thanks for the licence, i receive it quickly but I can't use the reset button!
The Licence has only 0kb so i thing it can not work!
Y15_S01E6_MOE001
DNPBT000303
10SW037916
300_4088000023978BAF
Global_13 PIDS active founds022_000000000003F7F2 023_000000FC7F730774 188_800B7FEF80A747E1 020_0000950000004BC4 174_1C800000A76A0E29 024_000000000020007F 080_19C00000102000A1 100_C712033035000013 178_0880042000800EE8 17C_000000000C960E6E 018_0002A000820047E7 019_9609600000000780 120_4A447A4460481479
ZDMAA00AAGB006873 OIL0_DES0
Re: Licence with 0kb??
Posted: Tue Aug 18, 2026 8:57 pm
the server is full actually.
we are working on it, i'll send you the lic when it'll be restaured
Posted: Wed Aug 19, 2026 4:44 pm
by Patrick959
i've got the same problem, licence with 0kb.... i see the server is full , can you provide some update and help me?
Posted: Wed Aug 19, 2026 8:53 pm
by chanchito86
I also received a license from 0kb; is this always due to the server or Outlook's AI-powered spam filter?
Posted: Thu Aug 20, 2026 12:48 pm
by onix05
Hi and thank you for the new licence!!
Now the connection works but i can not reset the oil service light!
Could it be because i have the MTS 1200S 2015 DVT? with the 10sw soft!??
I found this post: viewtopic.php?p=3611#p3611
that meens for me that at the moment it is not possible!? :(
This evening i will check if it is possible when i change the date in the bike.
Thanks for your support!!
Chris
Posted: Thu Aug 20, 2026 3:12 pm
i'm affraid the 10sw is the reason yes
Posted: Thu Aug 20, 2026 4:42 pm
by Kestas ducatis
Hello JP,
I have exactly the same problem.
My bike is a Ducati Multistrada 1200, year 2011, ECU MELCO 021.
Yesterday I registered the ECU and downloaded the cle.lic licence file, but the file is 0 KB.
When I try to register again, the website says that the ECU/serial number is already registered with my email address.
Could you please generate/fix my licence, as you did for the other user in this topic?
Thank you very much for your help.
Best regards,
Kestas
