Hi everyone,
In this days I Will finish to rebuild my Hypermotard 821 with ECU IAW 7SM. Before start my engine I have to reset the sensors on object and I want to know, when I will use Melcodiag, if I can reset the sensors or in this moment the function is not ready or their not work with this ECU.
Many thanks,
Reset MAP sensor and APS/TPS sensors
Re: Reset MAP sensor and APS/TPS sensors
the tps reset is supported on 7sm .
aps , i'mnot sure if it's possible
Ok,
I Will try at the end of this week for APS. I Hope, if reset won't function well, the Dash board present me some errore. Correctly?
About the reset MAP sensor, what do you think? It function or not well?
reset MAP is not implemented ; are you sure this function is supported on this configuration ?
Sorry but I didn't use the program because i'm rebuilding my Hypermotard. I read the istruction on Scrambler' forum and I think that istruction refer to another ECU.
Many thanks for your answer.
I tried to syncronis the TPS in my hyper 821 and i fount this result, after to push the TPS Reset: The sound of engine wasn't perfect when run
I check the MAP sensor (I rotate the gas for a little portion, please see the APS) and I didn't see nothing.
I remain with this porsion of gas for some second: I can some errors during reset TPS or when use the program?
I share with you the report that i make after those tests:
"File generated On 14/09/2026 19:33:40"
"Software version 2.0.5.4"
"Auto Detect Bike = Hyper 821"
"User Bike = hyper821exaust+airfilter+map"
"Softw = N/A"
080_00118450000000C8
024_37D87CC000000000
018_0000460000000003
020_0400FF03B8003D00
230_0000000000080000
300_40038310974D0840
"Vin = ZDMB200AAEB010600"
"00844E37"
? outp='ZDMB200AAEB010600'
PaniVIN: ZDMB200AAEB010600
"Softw = N/A"
"00844E37"
maybe those data haven't been tested with your bike yet .
you can help to add it by checking PID 024 and 080 with the monitor option.( coose a pid , and click on the value to pass it blue to be taken into accounty
aps shall move 0 to c8 , tps bytes shall be next the aps one
