"Get license" button not working
Posted: Mon Sep 14, 2026 10:08 pm
by Sleggt
Hi!
So I connected my computer to the motorcycle with Melcodiag running, and when I click on "get license", all I get is a never ending loading screen on the browser, and on Melcodiag, the ecu type goes from "blank" to "no ecu data" as I click on "get license". On Melcodiag, I can see my bike, VIN, kms, Software version and ELM V voltage. I am using the same Com channel as my adapter (COM4).
This is the interface I am using : https://www.amazon.ca/dp/B07MQ8GHG3?ref ... asin_title
This is the adapter I am using : https://www.amazon.ca/dp/B0FN3F3B8N?ref ... asin_title
This is the log I get when clicking "Write report" :
"File generated On 14/09/2026 4:48:45 PM"
"Auto Detect Bike = 2013 Hypermotard 821"
"User Bike = 2013 Hyperstrada 821"
"Hardw = ↕"
"Softw = 12"
" vin 145A8F035A444D3159425453364442303032373735
018_00005A0000000003
020_0400FF03BE003700
080_00114430000000C8
024_901EC2BB00000000
160_C8C800006564C2C1
150_0000535057504003
100_801208377937CE00
"Vin = ZDM1YBTS6DB002775"
"4000A6D3"
ZDM1YBTS6DB002775
ZDM1YBTS6DB002775
Any help would be appreciated, Thank you!
Re: "Get license" button not working
Posted: Tue Sep 15, 2026 3:46 pm
hey ,
have a look here
viewtopic.php?t=964
Posted: Wed Sep 16, 2026 9:46 pm
by Sleggt
Hey, thanks for the cue.
It seems to have worked and I've been able to add the license, but the program seems to be only partially working.
I can scan and delete codes, reset dash pin (did not try the service resets yet), interact with the dash in the active tests, do the fan/fuel pump tests, and some other stuff.
However, some parts don't seem to work
Main page : I do not see ECU information (written N/A in ECU type and software version, and nothing in hardware version), nor the temp data.
Active tests : Exhaust valve position 1 and 2 doesn't activate anything (I hear it on ignition on normally)
Passive tests : Only ones I've been able to see are the tc level on the first box, brake switch on the the third and I also see TPS angles V and H
Is this a pebcak moment or is there more to it?
Posted: Thu Sep 17, 2026 6:39 am
I will make a fonction for finding more data
Reset shall be ok
