Hello.
I have a similar problem with resetting the service warning.
The message about service only pops up when the ignition is turned on for the first 2-3 seconds, the key lights up and the odometer shows how many kilometers are left until service (example -7000).
This warning is not reset.
						Service, annual and desmo reset not working for 2016 M821
				albert-shot
Re: Service, annual and desmo reset not working for 2016 M821
hi @jp,
I've just tried again with date changed for 2026, but there is still no result.
When ignition is turned on, service light pops up and also the number of kms left until next service ~6200 and it doesn't change after reset buttons.
Below the reports from Melcodiag:
v2.0.2.4
"File generated On 01.08.2026 18:40:23"
"Software version 2.0.2.4"
"Auto Detect Bike = Monster 821"
"User Bike = Monster821/2016"
"Ecu = D141031BABGAG1U"
"Hardw = A2C9295020099"
"Softw = QD141010"
9 PIDS active founds
020_0600000196344000
024_0000000000173946
080_80004000000000C8
018_00005E0000000000
100_414128507E47D300
150_0000404B404B172E
160_000040408180C7C7
190_4000000004C9905
"Vin = ZDMM701AAGB001774"
"A48D2CFE"
***reset annual***
service date : 260801
***reset annual***
v2.0.4.4
"File generated On 21.04.2025 18:43:36"
" vin 145A8F035A444D4D37303141414742303031373734
vin 7F1A12
vin 7F1A12
vin 7F1A12
020_06000001A2374000
100_0141284F7E47D300
190_40
"A48D2CFE"
ZDMM701AAGB001774
0120
0160000000000000
0120
0160000000000000
Should I wait until the 6200 kms countdown is over and Desmo light is raised, then try again ? In the past, when desmo service light was raised, v2.0.2.4 worked and desmo light was erased and countdown was set back to 30k Kms.
v2.0.2.4
"Softw = QD141010"
190_4000000004C9905
"A48D2CFE"
***reset annual***
***reset annual***
v2.0.4.4
vin 7F1A12
vin 7F1A12
vin 7F1A12
190_40
"A48D2CFE"
ZDMM701AAGB001774
0120
0160000000000000
0120
0160000000000000
do you remember the version that worked ?
i'd be curious you test with the same one
yes, in the past I used the "desmo reset" button with v2.0.2.4 and it worked.
so we have no software regression , it's a good news for me
maybe you have to wait the km countdown yes
Yes, I'll wait for the "desmo service" light when the countdown is over and then I'll try again.
I'll let you know the result. Thanks a lot !
Hi JP,
Km countdown reached zero, service light popped up on the dash and I've just tried again to reset and it worked. So this was the catch. You have to wait for the countdown to end and then reset. Thanks a lot for your work !
PS: Is there an easier way to support your work with a donation beside paypal ? Maybe revolut ?
thanks for your feedback
only paypal for now
						only paypal for now
Maybe this has already been discussed, but I want to share my experience with the Monster 821 MY2018.
If the dashboard DATE and Clock are not correctly SET, the OIL, Annual, and Desmo resets will not work.
It is not necessary to complete the remaining indicated km , on the dashboard.
I think it's the same for the Monster 1200, but I haven't tried it yet.
what are you calling the clock ? computer clock ?
