999 meter cluster delete pissible?
Al Ton
Post by Al Ton »
hello !
i am working on customizing modifying an old 999...immo offed... servo start circuit defective (59M) ecu... other wise it running ok (separate starting solenoid circuit)
want to know if there is a way to run the bike without the stock Meter cluster / speedometer
i know it will prime the pump , injector spray upin starting but no spark
any advice would be gratefully appreciated
Re: 999 meter cluster delete pissible?
With immo off you don’t need cluster anymore for starting the bike
Al Ton
Re: 999 meter cluster delete possible?
Post by Al Ton »
thank you for prompt reply
here is what hapoens with my bike
with cluster off thw bike ..i turn key on hear the fuel pump whir...i crank the bike ( by passed servo start) i can see fuel injectors spray fuel but no spark...
doing it again with cluster plugged in turn key on and it g
its cycle..bike starts no problem.. unplug cluster while engine still running kill swith off and and on again will start bike , but if i turn key off and on again it will not start the bike without cluster
I kmow my immodilizer is off because its starting and running with the immo antena unolugged
In the tab unlock ecu / ecu virginity test what do you read ?
Al Ton
Post by Al Ton »
waiting for usb and fiat cables to arrive will post updates thank you
