yes it's the good one .
i don't understand what you mean by tool and diag
Connection issue with multistrada 1200s 2011
Re: Connection issue with multistrada 1200s 2011
Tried to connect with the DDA cable e seems working but stuck in "getting some pids" . I've waited for 10 min, now I will try waiting more time. Just for info to the others, only if you are on the "battery voltage menu" the ignition will stay on more than 5 mins otherwise will switch off automatically.
you mean you cannot naviguate to the other tab ?
maybe the message is just not refreshed
Yes, could be. I can navigate through the tabs.jpl250rs wrote: Mon Oct 20, 2025 4:40 pm you mean you cannot naviguate to the other tab ?
I can send the log as well for the license?
The report would be better
"File generated On 26/10/2025 18:42:14"
"User Bike = mts 1200s 2012"
"Ecu = MELCO HIMEJI "
"Softw = 00080003"
" vin DATA
vin 037F1A11
vin 7F1A31
vin 31A8FD07F1A31
0 PIDS active founds
"E01ED005"
u.
"Softw = 00080003"
" vin DATA
vin 037F1A11
vin 7F1A31
vin 31A8FD07F1A31
"E01ED005"
u.
- MelcoDiag.exe.debug.txt.zip
- (464 Bytes) Downloaded 57 times
