2015 Scrambler Heated Grip Activation
mullesh
Post by mullesh »
I’m curious is melcodiag has the ability to activate the factory heated grip option on a 2015 scrambler?
Just purchased a new bike yesterday which has the oem grips. Previous owner says they’ve never worked but also the dash doesn’t show them as available to turn on. My understanding is the dealer would typically need to enable this feature so I’m hopeful melcodiag can do this too.
Re: 2015 Scrambler Heated Grip Activation
if your bike has an m3c ecu ,it's not implemented for it ,but we can try together if the command is the same as for the other models
mullesh
Post by mullesh »
I’ll let you know if my bike has that ECU, I should have my parts this next week and will probably work on it the following weekend.
bgleyze
Post by bgleyze »
I can test too, I have a 2018 Scrambler Street Classic.
Thanks.
i'll explain how to do in pm
juku
Post by juku »
I also own a 2016 Scrambler.
Were you able to turn on the grip heater?
If possible, could you teach me how to do it as well?
Thank you!
what ecu is fitting your bike ?
bgleyze
Post by bgleyze »
bgleyze wrote: Sun Nov 02, 2025 5:04 pm Hi,
Thanks.
My ECU type : 5WY8691-AA in MelcoDiag.
Thanks.
juku
Post by juku »
Thanks for your reply.
My bike has a Continental/Siemens M3C ECU.
ok you both have a m3c ecu so
i have not coded the grip heater for it . we can try if they use same commands as other ducati
