Hi JP,
It seems that Melcodiag is not working anymore for my Monster 821 from 2016.
2 years ago I managed to reset the desmo service using version 2.0.2.4, but today I tried again and it's not working anymore. I also tried the latest version: 2.0.4.4 and still not working. Is anything changed ?
I have to mention that last time, the desmo light could be seen on the dashboard but now it has ~7000 km until it will be raised again. Just the oil service light is seen when the key is on. But I would like to reset the oil and desmo now due to service performed.
The report is below:
"File generated On 12.03.2025 20:34:52"
"Software version 2.0.2.4"
"Auto Detect Bike = Monster 821"
"User Bike = 2016"
"Ecu = D141031BABGAG1U"
"Hardw = A2C9295020099"
"Softw = QD141010"
024_0000000000163646
080_80004000000000C8
020_09000001660E3600
018_00004E0000000000
120_7803010000000002
200_00
"Vin = ZDMM701AAGB001774"
"A48D2CFE"
***reset annual***
service date : 250312
***reset annual***
I can see that only for reset annual the date is from today.
Can you help me ?
Thanks a lot for your work !
						Service, annual and desmo reset not working for 2016 M821
Re: Service, annual and desmo reset not working for 2016 M821
-7000km it seems reset
why the key is still visible on the dash , i don't know . is it maybe due annual service , what date you read for it ?
I was referring to the date from the report above. Yesterday’s date is for annual service.
Should I wait for the countdown of the ~7000 kms for the service light to appear and then try again ?
Based on the report it should work ?
Is it something changed from the last working version ?
Also this time I have low battery voltage. I need to replace the battery because the current one has under 12V. Could this be the cause ?
And I don’t think I really need the annual service reset because for this bike I didn’t see any annual service light.
I just want to reset the desmo service and oil service which worked 2 years ago, but yesterday when I tried, didn’t work anymore.
Thank you !
Thank you !
is the date of your PC when you pressed annual reset
you can try to change your pc date +1 year and press button again
I’ll try, thanks! And this could also solve the issue with desmo and oil service reset ?
i don't know , let me know if it works
Sorry, I've been away from home for a couple of days. I'll try next days and let you know the result. Thank you !
