Multistrada 950 2017 service reset not working
Qbnmulti950
Post by Qbnmulti950 »
I have been trying to reset my annual service indicator without success.
When I try to do the reset the service and date indicator on the dash flashes a few times but then remains on.
"File generated On 15/01/2026 10:30:52 AM"
"Auto Detect Bike = MTS950"
"User Bike = MTS950 2017"
"Ecu = UUUU"
"Hardw = UUU"
" vin 145A8F035A444D4141303541414842303230393830
11 PIDS active founds
024_0001000000200039
080_20A2BC00302000F2
100_C712000000000063
020_00409000000047D7
230_0000000000000644
018_0002A0008000485F
019_960960000000083B
188_800180018001078C
022_000000000003F7F2
023_000000548001072A
240_0000012D000963C0
"Vin = ZDMAA05AAHB020980"
"DTC = C712000000000344 C7120000000003449609600000000F68 C7120000000003449609600000000F68C71200000000050A"
"76CAEA15"
ZDMAA05AAHB020980
037F1A2200340400
service date : 260114
021001
0250010000000000
***reset***
ZDMAA05AAHB020980
037F1A2200500000
ZDMAA05AAHB020980
Qbnmulti950
Re: Multistrada 950 2017 service reset not working
Tried 2.0.4.9 Still without success in resetting service indicator.
I've tried changing date on the bike and on the laptop but there has been no change.
Any ideas on what else I can try, or is this one of those bikes where this software just doesn't work to reset the service indicator?
"File generated On 3/02/2026 6:02:36 PM"
"Ecu = UUUU"
"Hardw = UUU"
"Softw = 95313053"
188_8001800180010837
022_000000000003F849
023_0000005480010891
024_0001000000200124
018_0002A000800047E4
019_9609600000000780
080_2112BC003020012E
100_C71200000000017E
230_0000000000000EAC
120_40827E3518001CA7
200_0000000000000C96
"76CAEA15"
ZDMAA05AAHB020980
service date : 260203
0250033300C78000
037F1A2200C78000
Ezequiel
Post by Ezequiel »
Hola a todos. Tengo la misma moto MTS 950 2017. Creo que ECU Bosch, no estoy seguro del todo. ELM327 v1.4 y win7 :roll: . Llevo 3 años intentándolo y no lo consigo. Se conecta, genera el informe, los 3 años he recibido la licencia rapidísimo(gracias jpl250rs). Esta misma mañana lo he intentado y no hace el reset. Si que actúa diferente, porque los dos años anteriores el cuadro de instrumentos no hacia absolutamente nada. Ahora si, cuando le pides el reset la fecha y la advertencia de servicio se ponen parpadear. Pero a los 15 segundos suena un "ding" metálico en windows, típico ruido de "algo ha salido mal", y ahí termina el sueño de no acudir al concesionario...Pero la herramienta es gratuita, y el servicio que proporciona es muy grande y potente, no es justo quejarse. Tenemos que esperar un poco o estudiar más si es que alguien ya lo ha conseguido y no nos hemos enterado.
Publico informe, nunca se sabe...
"File generated On 16/04/2026 9:35:10"
"User Bike = MTS 950 2018"
"Ecu = UUUU"
"Hardw = UUU"
"Softw = 95313053"
" vin 145A8F035A444D4141303541414A42303235393038
10 PIDS active founds
188_80018001800105B6
022_000000000003F5C8
023_0000005480010510
018_0002A000800046F9
019_960960000000069D
020_0040900000004199
024_0001000000000FF7
080_2012BC0030000FA0
100_C712000000000FD8
220_0000000000000230
"Vin = ZDMAA05AAJB025908"
"E4B6D859"
ZDMAA05AAJB025908
Ezequiel
Post by Ezequiel »
PD: También he probado, durante los 15 segundos que parpadeaba la "date" y el "service", modificar la fecha de servicio con los mandos de la moto. Por descartar que durante esos 15 segundos de parpadeo, Melcodiag te esta dando acceso a modificar manualmente. Pero nada, ni reset 0, ni reset 1, ni cambio de fecha reset.
"lic not found"
you have to register with the blue button
Ezequiel
Post by Ezequiel »
Lo siento, genere el informe antes de obtener la licencia. Pero todo lo que describo sucede con la licencia obtenida y operativa. Publico igualmente el informe con la licencia ya integrada en Melcodiag. Un saludo y gracias.
"File generated On 17/04/2026 12:00:37"
"User Bike = MTS950 2018"
"Ecu = UUUU"
"Hardw = UUU"
"Softw = 95313053"
018_0002A00080004F0C
019_9609600000000F68
020_0040900000004D05
188_8001800180010E79
022_000000000003FE07
023_0000005480010EDF
024_00010000000008A4
080_2012BC0030200886
100_C71200000000088B
150_0000007800016392
180_D600300
"E4B6D859"
ZDMAA05AAJB025908
