Melcodiag Issues
Bandito
Melcodiag Issues
Post by Bandito »
I’m having trouble with the program freezing.
I’m trying to reset the service interval although the service light isn’t currently on.
It will connect to the bike, if I try to reset the service, the program freezes and stops responding. If I go on the active tests it will turn the fans on for instance but then the program freezes and stops responding.
Interestingly it will let me read and erase fault codes without the program crashing.
Any suggestions?
Re: Melcodiag Issues
it'll be fixed in 2.0.5.0 but that's not the reason why you can't reset service. the command is sent before freezing
