2015 Multistrada 1200s reset PIN code
Hello, I am so grateful for this software and I have been able to connect to my Ducati, however I have no luck with the PIN code reset. I can read DTC and clear the codes but the active/passive tests and PIN reset seem to do nothing. Is this a limitation due to the model and year of the motorcycle? Or maybe my adapter? It is a 2015 Multistrada 1200s DVT. I will try to reconnect with different connection speed perhaps. I am using a bluetooth OBD reader (OBDLink MX+) at default 38k speed. Thanks for any help.
Re: 2015 Multistrada 1200s reset PIN code
I've attached the debug file. I only just realized that the bike/ecu type is not showing after connecting. I can read codes, scan ecu and erase dtc but that's it.
"File generated On 2/15/2025 5:49:10 PM"
"ELM version : ELM327 v1.4b"
"User Bike = 2015 MTS1200 S"
" vin 145A8F035A444D3132425757304642303033323933
vin 7F1A12
vin 7F1A12
vin 7F1A12
21 PIDS active founds
024_0000000000200245
080_183000003020023A
100_C71203C040000226
018_0002A00082004A66
019_9609600000000A01
022_000000000003FA73
023_000000FC7F830A17
174_54800000146B01B6
178_EF7F0502A2800130
020_0000950000004D8A
17C_000000000A9601D0
188_801F7FEB80874A4A
300_339800002A3FCD6C
120_4AC47D4AE4481E33
130_0000050003E60A00
230_12801000002C0DC4
150_0002007C0000631C
210_00000042FF00A331
687_1000000000000C00
110_8109580440000E10
"Vin = ZDM12BWW0FB003293"
"1C3A5D13"
ZDM12BWW0FB003293
ZDM12BWW0FB003293
vin 7F1A12
vin 7F1A12
vin 7F1A12
"1C3A5D13"
ZDM12BWW0FB003293
ZDM12BWW0FB003293
ok we'll try differents commands, i'll give you a software for that
Hi guys,
yesterday night i tried to reset the dashboard pin code on my SFV4S 2020 with a licensed melcodiag 2.0.4.4 (either with an old version 2.0... with the same licence as weel)
The interface try to comunicate with the bike (flashing the leds on the elm) but I got no result in the dashboard menu. The dash ask me still the old pin to modify it...
Any help for my situation on that?
Very appreciated a support to, thank you
follow the debug:
"File generated On 09/03/2025 10:01:54"
"Software version 2.0.4.1"
"Auto Detect Bike = Streetfighter V4"
"User Bike = SFV4S 2020"
"Ecu = ÌÌÌÌ"
"Hardw = ÌÌÌ"
"Softw = 11CCCCCC"
" vin 145A8F035A444D4641303041414C4230303336XXXX
15 PIDS active founds
080_1C5226C025000078
100_C808000000000F16
018_0002A00084084803
019_96096000000308EF
120_6A0D7B0000011CFE
124_A6C8000000000C71
200_0000000000000C96
330_B76C591589EA0A1B
024_0000000000000117
174_0280005527800475
178_FC7F0C68F76504B9
17C_0C800100AE8F049C
020_0043990000004A81
022_000000000003F0A1
188_80
*Ecu found on : 7B0 ,*Ecu found on : 7B1 ,*Ecu found on : 7B2 ,*Ecu found on : 7B3 ,*Ecu found on : 7B4 ,*Ecu found on : 7B5 ,*Ecu found on : 7B6 ,*Ecu found on : 7B7 ,*Ecu found on : 7B8 ,*Ecu found on : 7B9 ,*Ecu found on : 7BA ,*Ecu found on : 7BB ,*Ecu found on : 7BC ,*Ecu found on : 7BD ,*Ecu found on : 7BE ,*Ecu found on : 7BF ,*Ecu found on : 7C0 ,*Ecu found on : 7C1 ,*Ecu found on : 7C2 ,*Ecu found on : 7C3 ,*Ecu found on : 7C4 ,*Ecu found on : 7C5 ,*Ecu found on : 7C6 ,*Ecu found on : 7C7 ,*Ecu found on : 7C8 ,*Ecu found on : 7C9 ,*Ecu found on : 7CA ,*Ecu found on : 7CB ,*Ecu found on : 7CC ,*Ecu found on : 7CD ,*Ecu found on : 7CE ,*Ecu found on : 7CF ,*Ecu found on : 7D0 ,*Ecu found on : 7D1 ,*Ecu found on : 7D2 ,*Ecu found on : 7D3 ,*Ecu found on : 7D4 ,7DC*Ecu found on : 7D5 ,7DC*Ecu found on : 7D6 ,7DC*Ecu found on : 7D7 ,7DC*Ecu found on : 7D8 ,7DC*Ecu found on : 7D9 ,7DC*Ecu found on : 7DA ,7DC*Ecu found on : 7DB ,7DC*Ecu found on : 7DC ,7DC*Ecu found on : 7DD ,7DC*Ecu found on : 7DE ,7DC*Ecu found on : 7DF ,7DC*Ecu found on : 7E0 ,7E8*Ecu found on : 7E1 ,7E9*Ecu found on : 7E2 ,7EA*Ecu found on : 7E3 ,7EB*Ecu found on : 7E4 ,7EB*Ecu found on : 7E5 ,7EB*Ecu found on : 7E6 ,7EB*Ecu found on : 7E7 ,7EB*Ecu found on : 7E8 ,7EB*Ecu found on : 7E9 ,7EB*Ecu found on : 7EA ,7EB*Ecu found on : 7EB ,7EB*Ecu found on : 7EC ,7EB*Ecu found on : 7ED ,7EB*Ecu found on : 7EE ,7EB*Ecu found on : 7EF ,7EB*Ecu found on : 7F0 ,7EB"
"Vin = ZDMFA00AALB00XXXX"
"D0FCE2E6"
ZDMFA00AALB00XXXX
follow the debug:
"Ecu = ÌÌÌÌ"
"Hardw = ÌÌÌ"
"Softw = 11CCCCCC"
188_80
"D0FCE2E6"
ZDMFA00AALB00XXXX
lapice78 wrote: Wed Mar 05, 2025 8:33 am Hi guys,
follow the debug:
"Ecu = ÌÌÌÌ"
"Hardw = ÌÌÌ"
"Softw = 11CCCCCC"
188_80
"D0FCE2E6"
ZDMFA00AALB00XXXX
thank god I got the pin from the previous owner and it works...
glad you got it
Same issue here for a friends 1200 Multi. I managed the Demso reset no problem, but PIN reset does nothing. He purchased his bike used etc etc.
Would be great for a fix.
