Ducati multistrada 950 2017
Hi been having a few issues connecting I am using a Bluetooth Lonelec cable to connect when I connect it shows the vin details but no ecu data if I switch it from any bike to m3c / med on the front screen and go to dtc find ecu it then finds the ecu and everything appears to work still no ecu shows on the front screen is this correct?
Re: Ducati multistrada 950 2017
can you post a debug report ?
button write report , paste the content of the new txt file
Sure out tomorrow will post on Saturday
Report below
"File generated On 03/07/2026 20:08:13"
"Software version 2.0.5.1"
"User Bike = 950 2017"
" vin:NO DATA>
020_00407000000003CD
360_A1440C03072601AE
188_800180018001078C
018_0002A000600048CF
019_960960000000083B
02100_C71200000000017E
220_0000000000000AD8
02_
*ECU found TX:7E0 RX:7E8
*ECU found TX:7E1 RX:7E9
"DTC = 7E80258005555555555"
"5682832F"
"registered"2_000000000003F7F2
023_000000548001072A
024_0001000020000161
080_2082BC00102001F7
" vin:NO DATA>
02_
"5682832F"
it looks like the paste and copy changed the line order and some carriage return are missing too
can you re do it ?
can you re do it ?
" vin:NO DATA>
02_
"5682832F"
" vin:NO DATA>
02_
"5682832F"
still the same
i don't know it's a elm issue , or a paste / copy issue.
do you have an other elm for testing
Sorry no I don’t it’s a Lonelec elm
"File generated On 04/07/2026 09:23:57"
0 PIDS active founds
"5682832F"
"5682832F"
a lonelec shall be fine
is it possible to remote your pc with rustdesk ?
