MV Agusta 750 f4s connecting impossible
grossben
Post by grossben »
I tried to connect on my MV 750 F4s (2001) but it is stuck on connecting status and the software says (no response).
I'm on Windows 11
With KKL cable
Thank you in advance
Best regards
Re: MV Agusta 750 f4s connecting impossible
Do you know the ecu model on this bike ?
Not sure it’s a 5sm
grossben
Post by grossben »
Thank you a lot for your repply,
To be honest, I don't know.
On the calculator, it's wtriten :
"Magneti Mareli
IAW 18M-ADF
16MU10F4U16_83P
CAGIVA MV F4 750
G1600.234.00 Z 12'/.."
Inside the calculator, I see on the EPROM : MV-F4 Murtas Motos. But it's a tag
Just beside the EPROM, I see a microship with : CA3262AQ
Thank you
no luck with jpdiag then , it's not a iaw5 something
i had an old project on 15m ecu , but it's still not a 18m
grossben
Post by grossben »
Thank you so much.
Do you know if an other tool exist for this model? Back then, there was VDST tool from techno research. But it seems that it doesn't exist any more...
Best regards
