Instrument panel/cluster replacement MSV4PP
bulldawgie
I’m trying to replace a cracked instrument cluster for a 2023 Multistrada V4 Pike Peak with a used one i got sourced. Will Melcodiag help me reprogram/transfer info/mileage/keys to the new panel from the old one? I’m a newbie here so no clue what this app is capable of. Thanks.
Re: Instrument panel/cluster replacement MSV4PP
no melcodiag can't hep you with that.
you also have the keys stored into the old cluster , the new one may not let you start .
have you try to start engine with the new one ?
bulldawgie
Hi thanks for the reply. Yes it starts up with the new one. But no mileage. Its interesting. When i connect the broken one Melco says it has 4848km on it and when i connect the new one i bought it says 5800ish km. i don't want to randomly add 1k kms to the bike!
i'mnot sure you can trust the mileage on the v4 , it has never been debugged on this model
the good news is you can start.
is the cluster can be disassembled ?
bulldawgie
No its just a smashed in screen but still fully assembled. i didn't want it to not be functional if i needed to plug it in.
Ok I see. I’ve no solution
I only know how to make it have more miles without open it
