Hi there,
I have only one "black" key for the bike and there is no info about code card I've received with my bike. I have been trying to code a new key but the dash asks for pin code which I don't have. Is there a chance to reset PIN using melcodiag software? Is it safe to go?
						Monster 696 2009 PIN Code Reset (Siemens ECU)
Re: Monster 696 2009 PIN Code Reset (Siemens ECU)
it's worth to try it , no danger
I have pushed the button named "Pin Code Dash" or sounds smth like that and nothing did happen (even some notification from app there were not). Still can't enter the dashboard and add a new key. What does the button "Key reset" mean?
Thanks!
						Thanks!
can you post a debug report ?
if you press key reset this message will popup : this will unpair your current keys and you will not be able to start the engine untill you pair new keys
"File generated On 13.05.2025 23:24:25"
"ELM version : ELM327 v1.3a"
"User Bike = monster 696 2009"
"Ecu = S180040101"
"Hardw = QD082010"
"Softw = 82IU1MID"
" vin:100E5A8C3238353321323732383920202220AAAAAAAAAAAA
6 PIDS active founds
010_0000000000000000
100_0000000000200001
020_0000005E9E000000
028_0000000000000000
080_0000000002000000
081_0300000000000000
"Vin = 285327289 "
"DTC = 025800AAAAAAAAAA"
"BC6C64FB"
285327289hard :QD082010
soft :82IU1MID
soft :82IU1MID
"Ecu = S180040101"
"Hardw = QD082010"
"Softw = 82IU1MID"
"Vin = 285327289 "
"BC6C64FB"
soft :82IU1MID
soft :82IU1MID
any ideas how to make this thing working?
ok thanks
do you hear a beep after pressing the button ?
nope ( there were no beeps at all and I had an impression that the app got freeze for several seconds just after pressing it
may be I am doing something wrong? I just pressed "connect", have seen IDs of the bike, then clicked on tab with resets feature and finally pressed the button
can you try this version and post the debug report after you press reset button ?
