2020 ducati mts 1260s GT......hook everthing up and tried multiple times but only get vin # anfd nothing else..won't even read mileage so cannot sent report to get license,,, did find the debug report and have copied it below: any help would be appreciated, I'm not that good with computers, so the simpler, the better......
https://jpdiag.akress.com/jpdiag.php?Lic=: : : : : 300_3A84000A0897C463: 18_: 80_: 100_: Global_ vin 145A8F035A444D4141454B57384C42303133383335
vin 7F1A22
vin 7F1A22
vin 7F1A22
022_000000000003F7F2
020_00007300000008EC
023_000000FC805F0778
188_7FEF7C7F7F87471C
240_0200500442000302
024_0000000000000FB1
080_1B32BCC010000FFA
100_C71203B039000F97
018_0002A000610045C1
019_96096000000005BA
174_1C800000FF690E89
178_1F800120CC780E12
17C_00000000B4930EEB
: ZDMAAEKW8LB013835 OIL0_DES0&UID=4E304E55
only reads vin# and will not send report to get license
Re: only reads vin# and will not send report to get license
Try to write on the first line- no ecu data-
That might send an email but not sure if he will get it. My 24 supersport is doing the same. Only reads VIN. I have the ELM327 V 1.5 with the toggle switch and the FDTI chip. Lets see if I receive a license.
UPDATE: I received the LIC and now I am registered but still the same issues on my side.
I trust In GOD
thanks for the reply and info.....just got license.....now to see if it works....
Hi
Did you ever resolve - I have same issue (ECU no information).
However I have the license and Melco Diag works, but when I try to reset the service light nothing happens.
MTS&PANI
you can you post the report ?
i had some issues on friday for generating licences , some are garbage
