Panigale V2 2021 Service reset not working
Simibro
Re: Panigale V2 2021 Service reset not working
Post by Simibro »
I just checked with the papers of my bike and it´s the same VIN. I guess the license is connected to the VIN right? When I try to request a new license I also get the info that the license for that vehicle has already been requested.
ok i'll issue a new one to be sure
Simibro
Post by Simibro »
I renamed the old cle.lic into cle_old.lic and tried it out with the new lic-file. Made sure it was unlocked, started melcodiag as administrator. The report is still showing "not registered", what else can I do to register it?
i don't undestand , is it possible to take a look on your pc with rustdesk ?
Simibro
Post by Simibro »
Is it possible to send you screenshots or a screen recording of the whole process?
Simibro
Post by Simibro »
I also noticed that the mileage it reads is incorrect and the rpm sensor shows numbers between 8000 and 8200 while the engine is off. May there be an issue with my elm adapter or driver?
you caan post screen shots here yes.
the live data are not yet added for your bike , don't worry if it reads erroneous things
jp
Simibro
Post by Simibro »
Alright, what information would be useful for you or what screenshots should I take?
Simibro
Post by Simibro »
Hi JP,
I did a screenrecording that is hopefully showing something helpful. I also made a screenshot were you can see that DTC is working fine.
This is the link to the video(it is only available for 2 days): https://streamable.com/pdhxqq
I attached the screenshot to this post.
Thank you for your help.
Screenshot 2025-03-11 103846.png (26.3 KiB) Viewed 5293 times
it really look a licence problem.
i would delete the one you have before putting the last one you got by email.
i'm affraaid it don't replace it if you simply copy it
i'd fix that by rustdesk in 2 minutes
