Panigale V2 2021 Service reset not working
Simibro
Post by Simibro »
Hi, I have been using MelcoDiag to reset the service on my 2021 Panigale V2 last year, which worked fine. This year however the reset just doesn´t work the way it did. The LEDs on my adapter are flashing and I hear a Windows sound but the service doesn´t reset. I tried to make it work somehow by trying different stuff out but I can´t seem to get it to work.
This is the output of my report file:
"File generated On 05.03.2025 15:59:05"
"Auto Detect Bike = Panigale v2 955"
"User Bike = Panigale V2 2021"
"Hardw = """
" vin 145A8F035A444D3148303041414D42303035353836
174_0680005B096B0EDA
178_FA7F0000E6860E2D
17C_02800100DD6A0EBC
018_0002A0006106401D
019_9609600000030007
024_000000000000032D
188_7FF77C377FF7489A
022_000000000003F849
18C_80037FFF000009FE
023_00000054800F087E
020_00407300000048AF
080_22A226C025200331
100_C812000000000205
"Vin = ZDM1H00AAMB005586"
"AE06B9E9"
ZDM1H00AAMB005586
***reset annual***
0250010000000000
service date : 250305
service interval
Re: Panigale V2 2021 Service reset not working
ok , but the licence is not recognized
cle.lic is unlocked ?
Simibro
Post by Simibro »
I checked and it was indeed locked. I unlocked it and tried again but still the same issue :(
Simibro
Post by Simibro »
This is the content of my new report file:
"File generated On 06.03.2025 09:32:17"
"Hardw = """
018_0002A000610648F5
019_96096000000308EF
080_1B4226C025200097
100_C812000001000F0B
020_0040730000004A95
300_2C98800E0DEFDDBF
174_0E800040A16B0B9E
178_F47F0000267F0B11
17C_FE7F01004A690B48
024_0000000000200162
190_8800000000000FC2
188_7FF7806B80AB4FDC
022_000000000003FF1A
18C_80037FFF0000000B
023_000000547F4B
"AE06B9E9"
ZDM1H00AAMB005586
try to run melcodiag with admin rights then
Simibro
Post by Simibro »
Hi, I have tried starting it as an administrator. Still the same result. The debug report is still showing "not registered".
reset buttons are enabled ?
Simibro
Post by Simibro »
Oh yeah I forgot to mention that. If I connect to the bike in M3C Mode the buttons are enabled. If I connect in "any bike" mode, they are not enabled. However if I connect in M3C mode once and then connect in "any bike" mode, the buttons are still activated. Does that have something to do with the "not registered" part?
Simibro
Post by Simibro »
I can think of two things that are "different" compared to when it last worked:
- The version of MelcoDiag was 2.0.3.7 last year when I successfully reset the service
- Since it last worked, the ECU was flashed once but it is now back on the stock map
it's possible your vin has changed ?
