Scrambler 800, 2023 nightshift
Re: Scrambler 800, 2023 nightshift
elm see the traffic , but seems not able to switch on ecu PID to discuss with it
is it possible to try an other elm ?
vijzen
Post by vijzen »
Thanks! I’ll try another interface.
Could you let me know which ELM327 model/interface you recommend for this?
I currently bought one from AliExpress — that one doesn’t seem to work fully.
Do you have a specific brand or model that you know works well with Ducati and MelcoDiag?
Thanks in advance.
those from lonelec, bmdiag, obdauto...i have some from aliexpress that works and some that are not working too
vijzen
Post by vijzen »
I’ve tried searching online, but I’m not completely sure which one you’re referring to.
Do you maybe have one or two direct links to the correct OBD cable, so I can be sure I’m ordering the right one?
Thanks in advance.
vijzen
Post by vijzen »
I tried again with a new USB ELM327 cable and tested in both modes (AnyBike and M3C/M3D).
Unfortunately the ECU is still not properly detected and the VIN is not read.
Below are the debug outputs from both tests.
"File generated On 21-2-2026 13:55:51"
"ELM version : ELM327 v1.4b"
"User Bike = scrambler / 2023"
"Softw = 11"
vin 7F1A11
vin 31A8F037F1A11
vin 7F1A11
vin 7F1A11
vin 7F1A11
vin 7F1A11
vin 7F1A11
vin 7F1A11
vin 7F1A11
vin 7F1A11
17 PIDS active founds
174_038000004F6B05D3
178_E47F0323E39505FD
018_0002A00000D04808
019_960960000000083B
020_0040111000000813
17C_00000000B98405EC
024_00000000000009FF
080_2352FFC0202009B4
084_4E328000000009B3
100_00020520000009E6
022_000000000003FC3D
023_000000547FA30CCF
188_7FFB7CCB805B4C38
18C_80238001800B0C25
150_0001107F0000020B
190_000000001F54B2B1
210_000000340001025D
"9C23B4A3"
second:
"File generated On 21-2-2026 14:00:13"
" vin:NO DATA>
18 PIDS active founds
024_0000000000000FB1
080_233300C020200F2B
084_4DF27E0000000F6F
100_0002052000000FA8
174_03800000526B0BE8
178_EF7F0125DB950BF7
17C_00000000C7840B0B
022_000000000003F29B
023_000000547F9B02F2
188_7FF37CCB8063420F
18C_801780017FFB0256
020_0040111000000F40
018_0002A00000D04F5B
019_9609600000000F68
240_0000812C00026E71
150_0001107E00000E0A
190_000000001F54BE2D
210_0000003000005E1D
"9C23B4A3"
