Page 2 of 2
Re: Multistrada 1200s 2013
Posted: Tue Apr 07, 2026 8:53 am
by Vestimy
Thank you very much, I'll check it out. I also think my exhaust flap is stuck. But thank you very much.
Posted: Tue Apr 07, 2026 3:11 pm
by Vestimy
**I found and fixed the problem. The cause was a seized exhaust valve.**
**During the inspection, I removed the valve cable, and after switching the ignition on, I read a servo motor fault with MelcoDiag. The fault was successfully cleared. The diagnostics are working correctly: faults can be read and cleared successfully.**
**Thank you very much for your help.**
