Page 2 of 3
Re: Panigale V4 2022 Annual Service/ Desmo not working
Posted: Fri Aug 22, 2025 5:49 pm
can you try each of the 3 buttons related to annual service data , and post the debug report ?
between each attempt , check if the annual is reset to know which button did the trick ( if one does)
check last version 2.0.5.0
Posted: Sat Aug 23, 2025 8:48 pm
by joxi1000
So first reset Oil service, second annual service, third desmo and then trigger the report if the annual works?
Posted: Sun Aug 24, 2025 3:46 pm
as i understood, oil or desmo reset works , just the annual service data couldn't be changed.
so i created 3 buttons only for annual service , i need report for each annual buttons
Posted: Mon Aug 25, 2025 7:03 pm
by joxi1000
Hi jpdiag,
So this is annual 0:
"File generated On 25.08.2025 21:00:22"
"Auto Detect Bike = Panigale V4 22"
"User Bike = Panigale V4 2022"
"Ecu = ÌÌÌÌ"
"Hardw = ÌÌÌ"
" vin 145A8F035A444D3344303041414E42303032343734
020_0043510000008A7F
080_1DC226C0252003C3
100_C8120150160002C3
018_0002A000400848A5
019_96096000000308EF
08A_0000000000002865
120_2A04800000012C7C
124_C600000000000C3A
200_0000000000000C96
330_165490C591BF088A
250_0000000000000D8B
174_F07F00539B6B0CD4
024_000000000000047E
022_000000000003FF1A
"Vin = ZDM3D00AANB002474"
"BC967C37"
ZDM3D00AANB002474
***reset annual***
0250010000000000
023E00
027E001200000000
annual service 1:
"File generated On 25.08.2025 21:01:58"
and the third "change service date":
"File generated On 25.08.2025 21:03:07"
"Ecu = ÌÌÌÌ"
"Hardw = ÌÌÌ"
"BC967C37"
ZDM3D00AANB002474
***reset annual***
0250010000000000
023E00
027E001200000000
023E00
027E001200000000
service date : 250825
031A9100
065A910025061900
031A9300
037F1A2225061900
***reset annual***
0250012225061900
>023E00
027E001225061900
>023E00
027E001225061900
031A9100
065A910025061900
031A9300
037F1A2225061900
***reset annual***
031A91250825
065A912525061900
031A93250825
037F1A2225061900
***reset annual***
031A91250825
065A912525061900
031A93250825
037F1A2225061900
"Ecu = ÌÌÌÌ"
"Hardw = ÌÌÌ"
"BC967C37"
ZDM3D00AANB002474
***reset annual***
0250010000000000
023E00
027E001200000000
023E00
027E001200000000
031A9100
065A910025061900
031A9300
037F1A2225061900
***reset annual***
0250012225061900
>023E00
027E001225061900
>023E00
027E001225061900
031A9100
065A910025061900
031A9300
037F1A2225061900
Posted: Mon Aug 25, 2025 7:05 pm
by joxi1000
The dash shows annual service dated since 19/06/2025, so none of the three created buttos worked sorry.
Posted: Mon Aug 25, 2025 8:15 pm
ok thanks , at least now i can check the correct date,
i'll keep investigate
Posted: Thu Sep 04, 2025 8:18 pm
by VioDuskar
I'm interested in this as well, as I have a 2024 Diavel V4 that the annual service button isn't working for.
I have the ELM V1.4, not the 1.5 though.
I tried both the website version of melcodiag, and the beta version with all three reset buttons listed here. I have not had luck with either.
I also attempted to reset the oil service and didn't have any luck either.
I have the Termignoni upmap, but reverted to original map before attempting any work with melcodiag.
Posted: Fri Sep 05, 2025 5:21 am
revert map is not necessary on newer bikes like yours
i'll keep working on this function
Posted: Mon Sep 08, 2025 11:07 pm
by ajcorrea
@jpl250rs
There´s some commands that i can try to execute in a "OBD2 direct shell" ?
I have ELM 1.4 and 1.5 and a Multistrada V4S
Posted: Tue Sep 09, 2025 4:34 pm
have you tried to add +1 year to your pc clock to see if that is working better ?
