Hi everyone,
I tried to reset my annual service and desmo, both are not working.
Just the oil service two months ago. Is my ELM maybe the problem? Or isn`t there any difference between 1.4 an 1.5 interface?
"File generated On 27.07.2025 14:40:10"
"Auto Detect Bike = Panigale V4 22"
"User Bike = Panigale V4 22"
"Hardw = """
" vin 145A8F035A444D3344303041414E42303032343734
018_0002A00040084277
019_960960000003023D
024_0000000000000230
08A_00000000000022B7
210_000000440000174E
330_EBAC90C591C109DA
080_1DA226C0252002A6
100_C812000000000122
020_0043510000008A7F
174_E47F00609C6B0E61
178_FC7F0A3404860EEF
17C_06800100216A0E57
188_80037C6B807B409D
022_000000000003F0A1
023_0
"Vin = ZDM3D00AANB002474"
"BC967C37"
ZDM3D00AANB002474
***reset annual***
0250012200000000
service date : 250727
Panigale V4 2022 Annual Service/ Desmo not working
Re: Panigale V4 2022 Annual Service/ Desmo not working
if your interface worked for the oil service , it shall be ok for the desmo as well
i just forget this function ,
now i updated it , would pleaase re download melcodiag and report if it is working ?
it's v2.0.4.6
it's v2.0.4.6
Thanks for your fast responding
Now the desmo light is off, but the annual service still isn`t possible to reset.
"File generated On 28.07.2025 15:51:57"
"Software version 2.0.4.6"
"Hardw = """
174_E27F0059AE6B0702
178_F47F000D868607C6
17C_FE7F0100536A079B
330_AB2C90C591E10450
024_0000000000000D8B
018_0002A00040084DCC
019_9609600000030D86
08A_0000000000002D0C
020_00435100000085C4
188_7FF77C3780674BCE
022_000000000003FB6E
023_000000547F9B0B07
18C_800B800300000C6E
080_1D4226C025200DC5
100_C812
"BC967C37"
ZDM3D00AANB002474
***reset annual***
0250012200000000
service date : 250728
"Hardw = """
100_C812
"BC967C37"
ZDM3D00AANB002474
***reset annual***
0250012200000000
for this check your dash board actual date , may be it is in the future
The date in motorcycle dahboard is correct with 28.07.2025.
It shows annual service due since 19.06.2025.
I was able to OIL SERVICE RESET on my 2022 Panigale V4S but not the Annual Service.
Annual service is stored in the dashboard while oil and desmo service are stored in the ecu .
There is 2 possibilities :
Either the dash ecu need a secure access and i’mnot able yet to calculate this key or
The elm is not listening when I send the command to change of ecu.
It’s impossible for me to diagnose without being connected to your computer
Eduardo yassunari
O tried service Bittencourt i couldan't do item either. I can read The errors but The reset does not work
your pc date is correct as well ?
Similar problem on my 2022 MultiStrada V4S .. all connected OK, but when I click on <annual service> to reset it, the computer gives a quiet 'chime' and nothing seems to change on the bike.
