				Multistrada 1200S 2011 Need Licence
				Posted: Mon May 19, 2025 8:09 pm
				by SpannerRash
				I have been trying to get a licence for Melcodiag for my Multistrada 1200S 2011.
I have connected using a ELM 321 1.5 cable, but the softwared doesn't seem to connect, and the information in the window is rejected by the message system when I try to send it for a licence.
I have tried 2011 and 2012.  I have changed the com port speed.
I have attached some images showing the kind of thing I have got.
I want to reset the PIN, and to check DTC's
				Re: Multistrada 1200S 2011 Need Licence
				Posted: Tue May 20, 2025 4:19 pm
				have you downloaded recently ?
the com speed is 38400 for a conventionnal ELM
can you post your debug report ?
				Posted: Tue May 20, 2025 5:49 pm
				by SpannerRash
				Thanks for getting back to me.
I have downloaded the Melcodiag software and used it straight away this week.
Your comment about conventional ELM  are you saying I have the wrong cable?
I  do not know how to find the "debug" report.  Please can you tell me how to get it.
				Posted: Tue May 20, 2025 6:24 pm
				button create report ,
check in the same directory as melcodiag the file MelcoDiag.exe.debug.txt file
if the button write report isn't activated after the init sequence , untick tick debug info request
				Posted: Tue May 20, 2025 8:05 pm
				by SpannerRash
				Here is a debug screenshot.
				Posted: Wed May 21, 2025 4:49 pm
				the com speed is ok , but you get no data from the ecu , the possible reasons could be :
- you dind't switch on ignition
- you are not connected on the diagnosis port
- your elm is not compatible ( we having problem with some v1.5 as yours)
				Posted: Wed May 28, 2025 6:46 pm
				by SpannerRash
				Just to update this thread.
I bought another ELM cable.
This time it worked.
Thanks for the advice.
				Posted: Tue Jul 22, 2025 9:45 am
				by Manieo3
				Hello.
Can you please tell me or send me a link with the cable that work for you? I have same issue like you and I don’t know what to buy.
Tkank you
