Multistrada 1200 (2010) - active test
Posted: Sat May 24, 2025 4:46 pm
I have an issue with MelcoDiag on my Ducati Multistrada 1200 (2010) with Melco ECU.
The program connects fine, I can read and clear error codes, and basic functions work correctly. However, when I try to use an active test (for example, set the speedometer to 50 km/h), the value is shown on the dashboard but then the program freezes and stops responding. I have to restart the software after that.
The license is activated and all functions should be available.
The battery is fully charged and on a charger during diagnostics.
No error codes are present in the ECU.
Windows drivers for the FTDI cable are installed and working properly.
At the program start, it is possible to select two model years: 2011 and 2012. I have tried both options.
Has anyone experienced a similar issue or have any advice on how to fix this?
Thank you for any help!
"File generated On 24.05.2025 17:52:37"
"User Bike = MTS1200/2010(2011)"
"Ecu = 070159538"
"Hardw = J001"
"Softw = 00000007"
" vin DATA
vin 037F1A11
vin 7F1A31
vin 31A8FD07F1A31
020_0000005154800000
080_06000000C8000006
018_000056000000C801
110_8032580440000E10
300_A406816507415400
230_0000000000000000
"F2632F93"
"Bike = 6"
"Ecu = 070159538"
"Hardw = J001"
"Softw = 00000007"
" vin DATA
vin 037F1A11
vin 7F1A31
vin 31A8FD07F1A31
"F2632F93"
"Bike = 6"
