Immobilizer Disable
Posted: Wed Jun 18, 2025 1:29 am
by shopPC1010
Is there anyway to disable the Immobilizer or get the PIN code from the ECU using the software ? I have a DTC E8 for the immobilizer “No or Poor Signal” and want to just disable it so I can run my bike.
Re: Immobilizer Disable
Posted: Wed Jun 18, 2025 7:37 pm
you need to reflash the ecu to disable the immo ,it's not possible via jpdiag only
Jpdiag can check if the ecu has the function disabled
Posted: Fri Aug 01, 2025 3:54 pm
by onrus
I have a writer program, but I can't rewrite, It tells me I don't have permission to install the map and remove the immobilizer. Could you please give me permission to write to 5aw, from your writerqc program? I could change the maps before. Thanks.
Posted: Fri Aug 01, 2025 8:15 pm
is it still the same ecu ?
the licence is unlocked and placed in the writer directory ?
