Immobilizer Disable
shopPC1010
Immobilizer Disable
Post by shopPC1010 »
Is there anyway to disable the Immobilizer or get the PIN code from the ECU using the software ? I have a DTC E8 for the immobilizer “No or Poor Signal” and want to just disable it so I can run my bike.
Re: Immobilizer Disable
you need to reflash the ecu to disable the immo ,it's not possible via jpdiag only
Jpdiag can check if the ecu has the function disabled
onrus
Post by onrus »
I have a writer program, but I can't rewrite, It tells me I don't have permission to install the map and remove the immobilizer. Could you please give me permission to write to 5aw, from your writerqc program? I could change the maps before. Thanks.
is it still the same ecu ?
the licence is unlocked and placed in the writer directory ?
