Streetfighter 1098s
slimjones
Streetfighter 1098s
Post by slimjones »
Hello all,
I have a 2010 Streetfighter 1098s that i am trying to reset the service wrench icon, as well as a TPS reset while im at it.
I purchased a 3-pin Fiat adapter as well as the KKL OBD adapter, I also have the ELM OBD adapter. I believe I have the necessary cables to use JPDiag.
I downloaded both JPDiag however i am unable to get the software working, it continually gives me an error message.
Am i able to download and use Melcodiag for my streetfighter 1098?
thanks
Re: Streetfighter 1098s
no , melcodiag wont works with a 5am ecu
jpdiag is correct , you need to enter the right com port number and switch on ignition before you press connect button
