Connection only lasts a few seconds
Posted: Mon Jul 21, 2025 2:32 pm
Hey everyone,
I'm trying to reset the service light on my Streetfighter 848. It has an IAW5 ECU, and I'm using JPDiag.
I'm using the same setup I used a few years ago on my Hypermotard 796: an ELM327 interface with an adapter cable that worked fine back then.
The issue:
Any ideas or suggestions would be greatly appreciated!
The issue:
- Ignition is on
- correct COM port selected (tried both 9600 and 38400 baud rates)
- JPDiag initially connects fine, but the ECU info screen stays blank
- After a few seconds, the connection drops
