2017 Diavel 1200 (Diesel) some connection but no VIN
HighPSI
Post by HighPSI »
Hi all. I am having dificulty connecting to my Diavel. I am using a USB ELM327 Described as this:
"ELM327 OBD2 USB Adapter, Diagnostic Coding Tool with MS-CAN/HS-CAN Switch Compatible with Ford F150 F250 Lincoln Mazda Mercury Code Reader Vehicle Diagnosis on Windows with V1.5 PIC18F25K80 Chip"
along with the 4 pin connector with correct pinout. When I select "any bike", there is not much reaction. Then I get asked 2011 or 2012. Not much either way.
When I select M3C, M3D, etc., The fuel pump cycles on connect, disconnect, pushing active test buttons, etc., It detects 3 different ECU's (no luck accessing codes), but I never get much information for the debug file. VIN is never read at all.
Where should I go from here? Let me know if I can supply different debug info. Any help appreciated :)
Debug file:
"File generated On 2025-08-03 10:35:04 AM"
"Software version 2.0.4.6"
"User Bike = 2017 Diavel 1200 Diesel"
" vin:NO DATA
3 PIDS active founds
?_
"C647B189"
HighPSI
Re: 2017 Diavel 1200 (Diesel) some connection but no VIN
Post by HighPSI »
Update:
I used an OBDLINK MX+ via bluetooth. Any bike, 38400 baud, and was able to get the VIN.
I've requested a license.
Just a note, sometimes at 9600, 38.4, or 57.6, I got "5" for "Software Version" instead of the 12000000. Not sure if that is significant to you, JP.
i don't know well the MX but the LX use 115200 bds
it looks like you have no data at all , is it possible you plug it on an other connector than the dda plug ?
