Hello everyone, I’m having difficulty with reading out DCT’s on my 2011 Ducati Diavel Carbon. I wonder what the issue might be because my adapter seems to connect to the bike but I cannot get it to read out DCT’s from any ecu(they are detected just fine), is it possible it might be due to the possible mistake when submitting the licence file ?
I already tried multiple cables and all get to same stage which is connected to the bike reading basic data like temperature,rpms etc but can’t get to the ecus themselves
Also is there anything also i have to do to use Bluetooth adapter ? Because software doesn’t want to detect any Bluetooth adapter I tried
Asking because when I submitted to get the licence for the bike I selected that the bike has oil service light active (which I don’t think is the case looking at it right now) it has green indicator with -6250 miles written on it can’t add a picture on mobile for some reason
Can line error
Re: Can line error
it's not a licence problem
if you don't scan ecus can it dispal the defaut DTC on 7e2 7ea ?
minestyle11231
Re: Can line error
Nope it gives the same answer for all the ecus it’s U1601 Can line error and B1009
Re: Can line error
so you have 2 errors in DTC screen
you can delete it and check if it comes back
minestyle11231
Re: Can line error
I tried deleting the can line codes, the code starting with U is gone
Debug report on the bike :
"File generated On 2/19/2025 7:54:47 PM"
"User Bike = 2011 diavel"
"Ecu = DNPBT001292"
"Softw = 000E0101"
vin 037F1A11
vin 7F1A31
vin 31A8FD07F1A31
6 PIDS active founds
022_0000000000009600
080_08000000C8000006
018_00005E0000000010
200_0000080000000000
020_00FFFF0000020000
110_6032580440000E00
*Ecu found on : 7DF ,7E9*Ecu found on : 7E0 ,7E8*Ecu found on : 7E1 ,7E9"
"DTC = F105580190096100 F105580190096100 F105580190096100 F105580190096100 F105580190096100"
"80BF7EDB"
"Bike = 6"
Now every single read of dtcs i do looks like this : 1
But the bike still has pressure sensor error present on the lower screen .
"Ecu = DNPBT001292"
"Softw = 000E0101"
vin 037F1A11
vin 7F1A31
vin 31A8FD07F1A31
"80BF7EDB"
"Bike = 6"
- image_2025-02-19_203451349.png (36.81 KiB) Viewed 4667 times
Re: Can line error
thanks for the report
so the b1009 is the pressure sensor error , i'll add it to the definition
