17 Supersport 939 only a couple things work?
Matteo
Post by Matteo »
I can:
-Reset service lights
-Check and clear codes
That seems to be it.
Does anything else in Melco work on this bike??
Also, the data like rpm’s, temp etc are way way off.
So I’m not sure what else this does.
Re: 17 Supersport 939 only a couple things work?
As you said there should have resets and dtc and maybe some actuators s well
For the other functions we can try to add it if you are willing to help
Matteo
Post by Matteo »
Would like to try the TPS reset if it works.
i’m having an issue with the track and I feel like it’s throttle related.
