Melcodiag will not reset Annual Service 2022 Diavel 1260S
Posted: Sun Feb 23, 2025 7:59 pm
by AregG
I am using MelcoDiag V2.0.4.4 and ELM327 V1.5
MelcoDiag reads the vin correctly but sees the bike a 2022 Dial 1260S as Xdiavel S2019, I assume that would be OK
However no matter has many times I have tried I can not reset the Annual Service last done by dealer on October 2023.
And dash indicator shows Oil Service -9306Mi Demo Service -17556Mi and Annual Service 24/10/06
Any ideas?
I would assume since they system reads the vin number correctly then the connection is OK
Re: Melcodiag will not reset Annual Service 2022 Diavel 1260S
Posted: Mon Feb 24, 2025 4:54 pm
can you post the debug report then i can see if the software version and the elm is ok ?
thanks
Posted: Tue Feb 25, 2025 12:01 am
by AregG
Thank you, here it is:
I tried again, and the service light is still on
"File generated On 2/24/2025 3:52:36 PM"
"Auto Detect Bike = Xdiavel S 2019"
"User Bike = 2022 Diaveel 1260S"
"Hardw = """
" vin 145A8F035A444D4741485257314E42303035333534
019_9609600000030754
174_E67F004EA8690074
178_00800132866B005C
020_0000551000000B4E
17C_F47F01009F7C000B
024_0000000000000BC5
080_1B12BCC010200BD3
100_0012040040000B88
188_7FE77DE7801742EA
022_000000000003F29B
023_000000007FC30209
018_0002A000420048FC
"Vin = ZDMGAHRW1NB005354"
"60818025"
ZDMGAHRW1NB005354
service date : 250224
Posted: Tue Feb 25, 2025 6:24 pm
setup / cables / registration all ok
we can try to change the bike type and give it an other try .
i'll send you instructions
Posted: Tue Feb 25, 2025 7:54 pm
by AregG
OK Thank you very much.
Posted: Sat Apr 05, 2025 5:17 pm
by Silentkr4ken
jpl250rs wrote: Tue Feb 25, 2025 6:24 pm setup / cables / registration all ok
Did changing the bike type get it working?
If so maybe the same fix will work for my issue (2020 Diavel 1260 showing as 2019)?
Posted: Wed Oct 01, 2025 3:42 pm
by AregG
Sorry for the late reply, unfortunately no.
Posted: Wed Oct 08, 2025 3:37 pm
by AregG
Few days ago I upgraded to the latest version of Melcodiag and still the same exact problem it will not reset period.
Posted: Sun Nov 02, 2025 3:57 am
by kambiz
Same here. 2021 Diavel 1260 S, auto detected as a 2019 xDiavel
I was however able to reset the oil light (a good indication that the tools worked), but then immediately comes on the Annual service light which have yet to make it work, no luck so far. Please keep posted if you found a solution.
Posted: Mon Nov 24, 2025 11:52 pm
by kambiz
Any updates?
