Melcodiag will not reset Annual Service 2022 Diavel 1260S
AregG
Post by AregG »
I am using MelcoDiag V2.0.4.4 and ELM327 V1.5
MelcoDiag reads the vin correctly but sees the bike a 2022 Dial 1260S as Xdiavel S2019, I assume that would be OK
However no matter has many times I have tried I can not reset the Annual Service last done by dealer on October 2023.
And dash indicator shows Oil Service -9306Mi Demo Service -17556Mi and Annual Service 24/10/06
Any ideas?
I would assume since they system reads the vin number correctly then the connection is OK
Re: Melcodiag will not reset Annual Service 2022 Diavel 1260S
can you post the debug report then i can see if the software version and the elm is ok ?
thanks
AregG
Post by AregG »
Thank you, here it is:
I tried again, and the service light is still on
"File generated On 2/24/2025 3:52:36 PM"
"Auto Detect Bike = Xdiavel S 2019"
"User Bike = 2022 Diaveel 1260S"
"Hardw = """
" vin 145A8F035A444D4741485257314E42303035333534
019_9609600000030754
174_E67F004EA8690074
178_00800132866B005C
020_0000551000000B4E
17C_F47F01009F7C000B
024_0000000000000BC5
080_1B12BCC010200BD3
100_0012040040000B88
188_7FE77DE7801742EA
022_000000000003F29B
023_000000007FC30209
018_0002A000420048FC
"Vin = ZDMGAHRW1NB005354"
"60818025"
ZDMGAHRW1NB005354
***reset date interval***
service date : 250224
setup / cables / registration all ok
we can try to change the bike type and give it an other try .
i'll send you instructions
AregG
Post by AregG »
OK Thank you very much.
Silentkr4ken
Post by Silentkr4ken »
jpl250rs wrote: Tue Feb 25, 2025 6:24 pm setup / cables / registration all ok
Did changing the bike type get it working?
If so maybe the same fix will work for my issue (2020 Diavel 1260 showing as 2019)?
I have a 2020 Ducati Diavel 1260
AregG
Post by AregG »
Sorry for the late reply, unfortunately no.
AregG
Post by AregG »
Few days ago I upgraded to the latest version of Melcodiag and still the same exact problem it will not reset period.
kambiz
Post by kambiz »
Same here. 2021 Diavel 1260 S, auto detected as a 2019 xDiavel
I was however able to reset the oil light (a good indication that the tools worked), but then immediately comes on the Annual service light which have yet to make it work, no luck so far. Please keep posted if you found a solution.
kambiz
Post by kambiz »
Any updates?
