Reset and Data problem with 2024 Ducati Multistrada V2 S
bridgenet
Post by bridgenet »
Hoping for some help resetting the Annual Service indicator. I am using Melcodiag on a 2024 Ducati Multistrada V2 S. I can connect with no problem. Have tried two different OBD 2 devices. One with ELM327 V1.4 and the other V1.5. Both worked the same where the data to monitor RPM shows a negative value when running and when not running the Annual Reset buttons do not work. Clicked Service Interval and I can see it sending and receiving data but not sure what it is doing. Below is the diag file when I was using V1.4, it showed about 12 RPM when that checkbox was enabled but the engine was not running. Have a feeling it thinks it is a different bike and parsing the CAN data wrong? Thanks in advance!
"File generated On 10/21/2025 2:14:19 PM"
"Auto Detect Bike = If your bike is not a 2010 to 2012 made ,please contact jpl250rs with your VIN and model bike"
"User Bike = Ducati Multistrada V2S / 2024"
"Ecu = UUUU"
"Hardw = UUU"
" vin 145A8F035A444D4141455854305242303131313530
150_0005007C00026418
210_00000035FF00F4B3
018_0002A00082C047C4
019_9609600000000780
020_0040950000004532
024_000000000000032D
080_1FC2BCC0100003C3
100_C712000000000344
174_0E8000001D6A0176
178_0080042F3B7901B5
17C_000000004B9401A7
022_000000000003FA73
023_000000FC7F8B0A4D
188_80037C2780874A9C
"Vin = ZDMAAEXT0RB011150"
"1EE542E3"
ZDMAAEXT0RB011150
Re: Reset and Data problem with 2024 Ducati Multistrada V2 S
you can download melcodiag again and give it a new try
iconpart
Post by iconpart »
I have similar problems. MelcoDiag 2.0.4.8
Mileage is reported as 10,041Km when it should be 40,164km. Air temp -40C. ECU and Hardware don't look valid (doesn't mean they are not but it inspire confidence).
"File generated On 23/10/2025 17:58:14"
"Auto Detect Bike = Multistrada V2 2022"
"User Bike = mts v2s"
"Ecu = UUUU"
"Hardw = UUU"
" vin 145A8F035A444D3241303241414E42303034323438
300_2F98002427390E48
230_131E1C00000CFE41
360_9301052310250025
018_0002A00062C04AD5
019_9609600000000B1C
024_0000000000000C96
080_1E12BCC030000CF1
100_C712000000001C32
174_0C800053D8690027
022_000000000003FD20
023_000000FC7F8F0D33
178_0680053037790056
020_0040750000004DA7
17C_F47F01000C940053
188_800B7C8F807B
"Vin = ZDM2A02AANB004248"
"967F1B32"
CAN ERROR
ZDM2A02AANB004248
those values hasn't been coded fortthis bike
only the resets and dtc can be trust
bridgenet
Re: Reset and Data problem with 2024 Ducati Multistrada V2 S -> Working now
Post by bridgenet »
Thank you, it works now on my 2024 Ducati Multistrada V2S. I was using 2.0.4.8 before but I see the date on your file changed in the new zip file so you must have made a minor code change and didn't bump the rev. I hit Annual Service 0, the screen background looked like it reset and went from white background to dark and the Annual Service went away during the refresh but came right back. Then pressed Annual Service 1 and it did the same thing, keeping the background dark and removing the Annual Service indicator. Cycled power and Annual Service is still off, the background I can go in and change back to white later. The Get Service Date, Change Service Date, and Service Interval don't work but that doesn't matter, Annual Service light is out. Below is the new debug file should it tell you anything and I used the newer ELM327 V1.5 but am sure V1.4 would have worked as well as both connected fine last time. The Auto Detect field is populated this time and was not with the prior V2.0.4.8 so that is a good sign. Didn't try the rpm but will if you want me to. From your prior post I am assuming you haven't coded that yet for this bike.
Thanks again!
Kev
"File generated On 10/25/2025 4:43:46 PM"
"Auto Detect Bike = Multistrada V2S / 2024"
"User Bike = Multistrada V2S / 2024"
"Ecu = UUUU"
"Hardw = UUU"
024_000000000000047E
080_1E92BCC010000489
100_C712000000000417
174_118000003B6A0281
178_FD7F08202579026F
17C_000000002E940259
150_0005007B0002696D
210_00000030FF00B9F2
018_0002A00082C04962
019_9609600000000926
022_000000000003FB6E
023_000000FC7F8F0B7D
188_80137C1780874BFA
020_0040950000004615
"1EE542E3"
ZDMAAEXT0RB011150
