when i enter card code ...
Bageldog1
Post by Bageldog1 »
when i enter card code it gives me a code do i than enter that into file dump and do i start with the word code or just start with recu and the numbers.... thanks
Re: when i enter card code ...
where does that give you a code??
Bageldog1
Post by Bageldog1 »
yes code recu0403080703
Bageldog1
Post by Bageldog1 »
it gives me code recu0403080703 under unlock edu when i enter the code
isn't the same one you just entered ?
Bageldog1
Post by Bageldog1 »
aftr research i was told if i ask you for a license i could flash one ecu is that true if so could i plz my original ecu map was deleted
the flashing licence is paying .
it allow to flash and also do some tunes
Bageldog1
Post by Bageldog1 »
how much and how do i pay will this get my bike to run if i load correct file thanx
One lic ecu cost 100€
If your issue is immo , yes it has option to make it virgin again or to remove immo
What bike is it ?
It can be purchased by PayPal with your ecu serial number in comment
Bageldog1
Post by Bageldog1 »
i paid 600 to guy who said immo removal was immopossible he made me a new key and it went bad shortly after all i wanted was this immo removed can u send me a link to your paypal and guarantee this will work thanks again heres my computer info by thee way
28640711B
: IAW5AMHW103
: 00
: 1211DG12
: 0000
: 5AMA3
: AA AA AA AA AA
: DUC
: 20 04 05 13
: 45+-67C1E
