2003 620S ECU data Bad
mcsputnik
Post by mcsputnik »
Greetings,
Inherited a monster 620S with a chopped rear end and no Cat.
Plugs are soaking wet, guessing I need to update the ECU map.
However, this is all that gets spit out when I try to register:
IAW59MHW010
00
0000
00 00 00 00 00
LOADF:2.10
20 02 11 26
Pas de n° de série
which is rejected when I submit.
Re: 2003 620S ECU data Bad
iaw59 don't need licence for activating buttons
mcsputnik
Post by mcsputnik »
understood, im able to get reasonably accurate data from JPdiag, and dont "need" to register.
However, among other things I wanted to check was that the dash mileage matched.
Was curious if anyone had seen a similar bug, and whether filtering was useful or what ended up concluding.
mcsputnik
Post by mcsputnik »
Also, also I assume if I want to use the ECU map dump (ECU276c) I need to register?
if you want to reflash , you need to purchase a writer licence.
you cannot check the mileage with jpdiag
