2019 Scrambler 1100 Sport - not reading bike info
mpaganini
Post by mpaganini »
Hello!
I have a 2019 Scrambler 1100 Sport and am using MelcoDiag v2.0.4.8 with an ELM327 v1.5 OBDII interface (switch in the HS CAN position) and 4-pin adapter cable. With this setup, I have tried both the "Any bike" and "M3C" ECU options and I am experiencing the exact symptoms as described by user yannickdebrest in this topic:
viewtopic.php?p=2144#p2144
Is it possible that you need to patch MelcoDiag to work with my motorcycle like you did in the post above? If yes, the first 7 characters of my VIN are ML0KAFC.
I'm looking forward to your reply. Thanks and regards,
Mike
Los Angeles, California USA
Re: 2019 Scrambler 1100 Sport - not reading bike info
KAFC no need to be patched ,yours seems to have a m3c ecu ,
can you issue a debug report ticking this option ?
mpaganini
Post by mpaganini »
Thank you for your response. Here is the data from the debug report:
"File generated On 2/6/2026 3:56:06 PM"
"User Bike = Scrambler 1100 Sport / 2019"
" vin:NO DATA>
024_0000000020000200
080_1E71E70345000287
150_0003107B0002498D
188_7FF77DC7801B47AA
020_0040501000008AFA
022_000000000003F7F2
023_000000547FFF0729
174_198000000B940EEA
178_0680000062840E68
17C_000000000C970E22
018_0002A00040C048DC
019_960960000000083B
100_C812110000000281
"921BCC66"
Note that I have NOT tried requesting a license or resetting anything because the ECU information has not successfully been read.
Thank you for your support!
Mike
it's strange , no data can be grabbed ,i'd try an other elm device
