2019 Scrambler 1100 Sport - not reading bike info
Posted: Sat Jan 31, 2026 9:24 pm
Hello!
I have a 2019 Scrambler 1100 Sport and am using MelcoDiag v2.0.4.8 with an ELM327 v1.5 OBDII interface (switch in the HS CAN position) and 4-pin adapter cable. With this setup, I have tried both the "Any bike" and "M3C" ECU options and I am experiencing the exact symptoms as described by user yannickdebrest in this topic:
viewtopic.php?p=2144#p2144
Is it possible that you need to patch MelcoDiag to work with my motorcycle like you did in the post above? If yes, the first 7 characters of my VIN are ML0KAFC.
I'm looking forward to your reply. Thanks and regards,
Mike
Los Angeles, California USA
Mike
