i clicked the MAP BUTTON !!!
coolestartist
Post by coolestartist »
I used the Melcodiag for Mitsubishi ECU
ON:
2016 Ducati 1299 base
I cleared the service codes. I clicked on the “MAP” button and now bike wont start. Did I remove the engine map on the bike by mistake?
Any suggestions how this can be restored?
Thank you!
Re: i clicked the MAP BUTTON !!!
map button is for relearn map sensors , it has nothing to do with the mapping.
you can try to reset the bbs/ecu disconnecting the battery for few minutes , and check if the bike back to life.
no error codes stored?
idaka
Post by idaka »
MAP = Manifold Absolute Pressure
Just to clarify
Best Regards
