Panigale v4s
jkaygee
Panigale v4s
Post by jkaygee »
I have used Melcodiag for a couple of years but have not had any issue, but at the minute when it hooks up the mileage, rpm etc doesn't show up correctly also doesn't show the type of ECU etc and I can't for the life of me reset the desmo service which was done this year ...... tried everything, any ideas
Re: Panigale v4s
do you mean it has worked fine before , but not actually ?
have you tried without firing the engine ?
jkaygee
Re: Panigale v4s
Post by jkaygee »
Yeah I've actually used it to reset a service light before, I did the desmo early and wanted to reset but it's not working, also the remote and mileage not showing correctly when refreshing, not even close, on idle it shows as 8300 room and my mileage as 5k when it's actually nearly 15k, I hooked up my up map dongle and it shows everything correct and can reset dtc's
Re: Panigale v4s
can you post a debug report for checking ?
jkaygee
Re: Panigale v4s
Post by jkaygee »
Yeah ill upload tomorrow
jkaygee
Re: Panigale v4s
Post by jkaygee »
Sorry still not managed to get to this will do it as soon as I get putto the bike
jkaygee
Re: Panigale v4s
Post by jkaygee »
Hi here is the report , tried everything to get this light reset just wont work, strange thing is when i hit the button it thinks about it but there is no Tx Rx on the ELM, also when it is communicating doesnt show the correct revs temp mileage but tx rx is flashing
"File generated On 12/04/2025 12:44:43"
"Auto Detect Bike = Panigale V4"
"User Bike = V4/S 2018"
"Hardw = """
"Softw = 22000000"
" vin 145A8F035A444D4441303041414A42303033383232
174_22800000816B0F9A
178_11800D2F89860F40
17C_00000000CF690F1E
100_C808001000000A5A
330_8D1890D60546029F
018_0002A0008000428D
019_960960000003023D
020_00419100000046E6
022_000000000003F849
023_000000547FAF08CC
024_0000000000008BE3
080_242226C005200B9A
120_2A448100000015B5
124_0000000000000563
17D_F
*Ecu found on : 7DF ,7E8*Ecu found on : 7E0 ,7E8*Ecu found on : 7E1 ,7E9*Ecu found on : 7E2 ,7EA*Ecu found on : 7E3 ,7EB*Ecu found on : 7E7 ,7EF"
"Vin = ZDMDA00AAJB003822"
"B64027DE"
ZDMDA00AAJB003822
***reset annual***
0250012200000000
service date : 250412
service interval
s6otty
Re: Panigale v4s
Post by s6otty »
Hi, I’m having similar issues.
How are you generation the debug report?
I’ve tried, it says done, but nothing on the clipboard.
Scott
jkaygee
Re: Panigale v4s
Post by jkaygee »
"Hardw = """
"Softw = 22000000"
17D_F
"B64027DE"
ZDMDA00AAJB003822
***reset annual***
0250012200000000
service interval
Re: Panigale v4s
i check the code , RX TX light shall blink with your bike , can you double confirm that ?
