Diag
Cedric02
Diag
Post by Cedric02 »
Bonsoir à tous merci à ceux qui prendront de répondre, hypermotard 821 2016 17000km ligne complète un voyant moteur est apparu « error » a l’écran 1min apres le démarrage( je soupçonne une sonde lambda) aux melcodiag aucune erreur ne ressort à moins que je mis prenne mal (novice c’est la première fois que je l’utilise) je vous joint le rapport
File generated On 01/04/2025 19:09:48"
"Auto Detect Bike = Hyperstrada 2015"
"User Bike = hypermotard 821 2016"
" vin 145A8F035A444D4233303046414642303031333038
11 PIDS active founds
240_6188E00000A89D00
080_0011C470000000C8
024_9FDFC03700000000
018_0000460000000002
020_0600CD03CA004700
160_C8C800006564CAC9
150_0000545058500008
100_401228657A47D600
210_0000000000000000
02_
*Ecu found on : 7DF ,7E8*Ecu found on : 7E0 ,7E8*Ecu found on : 7E1 ,7E9*Ecu found on : 7DF ,7E8*Ecu found on : 7E0 ,7E8*Ecu found on : 7E1 ,7E9*Ecu found on : 7DF ,7E8*Ecu found on : 7E0 ,7E8*Ecu found on : 7E1 ,7E9*Ecu found on : 7DF ,7E8*Ecu found on : 7E0 ,7E8*Ecu found on : 7E1 ,7E9"
"Vin = ZDMB300FAFB001308"
"DTC = NO DATA NO DATANO DATA NO DATANO DATANO DATA NO DATA NO DATANO DATA NO DATANO DATANO DATA 037F1811 037F1811037F1811 037F1811037F1811037F1811 037F1811 037F1811037F1811 037F1811037F1811037F1811 037F182200000000 037F182200000000037F182200000000 037F182200000000037F182200000000037F182200000000 037F182200000000 037F182200000000037F182200000000 037F182200000000037F182200000000037F182200000000 037F1811 037F1811037F1811 037F1811037F1811037F1811 NO DATA NO DATANO DATA NO DATANO DATANO DATA 037F182200000000 037F182200000000037F182200000000 037F182200000000037F182200000000037F182200000000 037F182200000000 037F182200000000037F182200000000 037F182200000000037F182200000000037F182200000000 037F1811 037F1811037F1811 037F1811037F1811037F1811 037F1811 037F1811037F1811 037F1811037F1811037F1811 NO DATA NO DATANO DATA NO DATANO DATANO DATA 037F182200000000 037F182200000000037F182200000000 037F182200000000037F182200000000037F182200000000 037F1811 037F1811037F1811 037F1811037F1811037F1811 NO DATA NO DATANO DATA NO DATANO DATANO DATA"
"142F51F1"
ZDMB300FAFB001308
Re: Diag
il faut aller dans l'onglet dtc appuyer sur le bouton dtc pour voir si l'ecu 7e2 contient des erreurs
s'ils n'en contient pas , il faut vérifier les autres.
pour les trouver il faut cliquer sur le bouton scan ecu
ils vont etre listés , il faudra en choisir 1 en cliquant dessus puis appuyer à nouveau dur le bouton dtc .
et le faire pour tous les ecu jusqu'a trouver celui qui a une erreur enregistrée
Cedric02
Re: Diag
Post by Cedric02 »
C’est bien ce que j’ai fait mais sa me dit «  no answer »
Cedric02
Re: Diag
Post by Cedric02 »
Bonsoir, j’ai refait un Diag est appliqué tous ce que vous m’avait dit est sur les 6 calculateurs j’ai la même réponse «  no answer On»
Est ce normale ?
