Diavel 1260s - 2019 - Service info
Posted: Fri Jun 26, 2026 10:37 am
by q.dance
I own a 2019 Ducati Diavel 1260S.
Software: 10SW0449218
VIN: ZDMGE00AAKB001069
I’ve just had the Desmo service and the annual service done, and I’d like to clear
the service notifications using your software, but I’ve run into a problem.
Here’s the situation:
1. I connected the motorcycle. - OK
2. I read the data (it only picked up the model, VIN, and software version)—unfortunately, it didn't retrieve the ECU and hardware data. :(
3. I registered the license. - OK
4. I copied it into the application folder. - OK
5. I launched the app, and everything works fine—except for resetting the service and Desmo indicators.
Do you happen to know what the problem might be?
In attachment photo.
Re: Diavel 1260s - 2019 - Service info
Posted: Fri Jun 26, 2026 5:02 pm
still the 10sw software
i have not found yet why this one in particular is so difficult to reset on some bikes , and working on different ones
Posted: Mon Jun 29, 2026 6:09 pm
by q.dance
So unfortunately, no one has been able to resolve this issue? :(
I've attached the log file below.
Do you have any alternatives?
Code: Select all
"File generated On 26.06.2026 11:49:41"
"Software version 2.0.5.0"
"Auto Detect Bike = Diavel 2019"
"User Bike = 2019"
"Hardw = N/A"
"Softw = 10SW049218"
15 PIDS active founds
024_000000000000047E
080_1B62BCC050000411
100_C70604004100045C
174_F27F005E74690209
178_0A8004357B6C02D1
020_0000BB1000008A1E
110_00004310000C6805
17C_00800100B17902A0
150_0006007B000049B8
210_0000005AFF0009FB
188_7FF77C637FA34A2C
022_000000000003FA73
023_0000000080470A0B
018_0002A000A5004BC1
01_
*ECU found TX:7E0 RX:7E8
*ECU found TX:7E1 RX:7E9
*ECU found TX:7E2 RX:7EA
*ECU found TX:7E4 RX:7EC
*ECU found TX:7D4 RX:7DC
"Vin = ZDMGE00AAKB001069"
"E6F23D1B"
PaniVIN: ZDMGE00AAKB001069
***reset date interval***
service date : 260626
Posted: Wed Jul 29, 2026 2:45 pm
by Diavel1260
I literally couldn't even get this far with my 2020 Diavel 1260. Just stuck on setting up ELM the entire time. Couldn't even pull the info down to submit the license. No one has had success here from what I've seen with these bikes. Star OBD seems to be the only way forward.
