2020 Streetfighter V4S Ducati Racing MAP Akrapovic
Ridevannn
Post by Ridevannn »
I have a 2020 Ducati Streetfighter V4S equipped with an Akrapovič exhaust and the official Ducati Racing ECU map installed by Ducati.
I would like to use MelcoDiag only to reset the annual/oil service indicator after performing the maintenance.
Before doing so, I would like to make sure that using the service reset function in MelcoDiag cannot erase, disable or affect the official Ducati Racing ECU map.
I have seen recommendations to restore the stock map before using MelcoDiag when an UpMap/T800 map is installed. Does this precaution also apply to the official Ducati Racing map installed by Ducati, or can I safely perform the service reset without affecting it?
Thank you for your help.
Best regards,
Evann
Re: 2020 Streetfighter V4S Ducati Racing MAP Akrapovic
no risks on those newer generation
