Re: Ducati Panigale 1199 R 2016
Posted: Wed Aug 12, 2026 9:44 pm
by RickM
Hi
so i have connected ok with bike. i can read things like TPS, MAP sensor, engine temp all these things.
But i am unable to reset TPS, it opens a new Melco Diag front page which is not connected, so i have 2 melco diag running, the new one has the warning about resetting/loosing UPMAP. I have to shut the Melcodiag s/w down in the taskbar. S/W version is 2.0.4.9
My PC is windows 11.
Posted: Thu Aug 13, 2026 12:45 pm
sounds strange , cn you try with the version 2.0.5.2 ? then i we have same version to compare
Posted: Thu Aug 13, 2026 2:35 pm
by RickM
Hi JPL
so i have loaded version 2.0.5.2, this now allows me to reset the TPS and APS. I also found that the ECU's can be read properly now.
Some other buttons like the Clutch switch, Fan test are not working.
Screenshot 2026-08-13 144654.png (88.24 KiB) Viewed 42 times
Posted: Thu Aug 13, 2026 4:15 pm
thanks for the feed back
for the live switch status you can help to debug in the passive tan
for the fan test i'm surprise it don't works , i will check later
