Melcodiag activation Monster 1200s
Achille1983
Good evening, I'm trying to get the data to activate the license but the connection only shows VIN and motorcycle type, why?
"File generated On 21/07/2025 23:40:21"
"Software version 2.0.4.5"
"Auto Detect Bike = Monster1200S"
"User Bike = 2014"
" vin 145A8F035A444D4D36303041414542303030373032
vin 7F1A12
vin 7F1A12
vin 7F1A12
9 PIDS active founds
018_0000460000000005
022_0000000000050000
024_0000000000123146
080_80000000000000C8
020_0600000130004300
100_024128427D45CF00
150_0000404B404B5629
160_000036368180C3C3
190_3800000000
"Vin = ZDMM600AAEB000702"
"9811344F"
ZDMM600AAEB000702
Thank's
"User Bike = 2014"
vin 7F1A12
vin 7F1A12
vin 7F1A12
190_3800000000
"9811344F"
ZDMM600AAEB000702
Thank's
Re: Melcodiag activation Monster 1200s
Maybe a non compatible elm , usually we get more data :
Achille1983
I understand, so you can't get the exact license information from this data?
Besides the ELM327 cable, what other cables are compatible? KKL, Galletto Scanmatik?
Thanks for your time.
Achille1983
Hi Jp, I tried with two other ELMs and nothing, same thing and same data, only VIN. How can I send you the rest? Would the ECU label be enough? Engine
i wouldn't suggest the no name elmv1.5 , we having a lot of trouble with
only elm cables are compatible and prefer the V1.4 , the command set is more complete
i don't need the missing data , you can still register , but i'm not sure that will works for some actions
Achille1983
Can we try to activate it? Do I have to send the request again? Thanks again.
yes try it one pore time plz
Achille1983
Ok thank 's it's works but when select test and reset i donate know if It works what i Will see?
what you will see after pressing reset button?
the wrench disapperar if it works
Achille1983
Hi JP, I'm referring to the TPS reset and others. I see the LEDs on the ELM cable working, but no message from the program. Also, on the Monster 1200, the TPS reset doesn't work in the Ride-by-Wire menu, but the other TPS reset does. I always notice this from the LEDs on the cable.
Thank's
Thank's
