try to unlock the cle.lic file
right click on cle.lic and choose properties , untick unlock ..
Melcodiag and license.
Re: Melcodiag and license.
Hello again, friend.
I've already unlocked the license file, unfortunately, it didn't make any difference.
Today, I tried again to connect to the motorcycle and trace the fault code it's displaying, but it wasn't possible; I can't read any codes.
What else could I do?
What am I doing wrong?
- Sin título1.png (51.55 KiB) Viewed 7576 times
- Sin título.jpg (92.66 KiB) Viewed 7576 times
unlock cle.lic in file properties , and give melcodiag admin rights
It didn't work, it still doesn't let me see the check engine light fault code...
I have Windows 11, couldn't that be the problem?
windows 11 is fine
Finally, it worked!!!!
With the new license file you sent, I was able to access my fault codes and reset the 12,000km service interval.
Thank you so much, my friend. I'm so glad it worked, and it's all thanks to you.
Truly, thank you so much.
- Melco1.jpg (81.97 KiB) Viewed 2241 times
- Melco2.png (53.91 KiB) Viewed 2241 times
