Upmap on Ducati Panigale 899
CarstenP2
Post by CarstenP2 »
Hi
Have a Ducati Panigale 899 year 2014 which I use on the track, bought the bike used and on the ECU is hat a sticker with the text Upmap, I dont have the dongle to take of the Upmap, made contact to Upmap they cant help, I can buy a new one
Bike idle poorly and goes up to 5000 rpm sometimes by it self, and are running fat
Have checked ECU for errors with JP diag, no errors
Checked map sensors, these is okay, even tried new ones
I would like to make a reset of my Map sensors with JP diag, but it gives me a warning that I could loose my Upmap, my questions is could I destroy my ECU if I make the reset of map sensors?
You would have the UPmap on your bike does it show that in the display? seen others writing that it says RACING EVO, mine dont!
And thanks for a fantastic forum
BR Carsten :mrgreen:
Re: Upmap on Ducati Panigale 899
well you mean you are using melcodiag
do not worry , you have no switchable umap on the 899 , it'a a complete reflash , yo are not concerned with this issue.
it could be a dead map sensor , check my video on youtube to determine which one is defekt cause the error is not recorded by the ecu
https://www.youtube.com/shorts/RZEVf8YMnfo
when you unplug / replug the defekt one nothing happen while engine is running
