Hi, I have been using MelcoDiag to reset the service on my 2021 Panigale V2 last year, which worked fine. This year however the reset just doesn´t work the way it did. The LEDs on my adapter are flashing and I hear a Windows sound but the service doesn´t reset. I tried to make it work somehow by trying different stuff out but I can´t seem to get it to work.
This is the output of my report file:
"File generated On 05.03.2025 15:59:05"
"Auto Detect Bike = Panigale v2 955"
"User Bike = Panigale V2 2021"
"Hardw = """
" vin 145A8F035A444D3148303041414D42303035353836
174_0680005B096B0EDA
178_FA7F0000E6860E2D
17C_02800100DD6A0EBC
018_0002A0006106401D
019_9609600000030007
024_000000000000032D
188_7FF77C377FF7489A
022_000000000003F849
18C_80037FFF000009FE
023_00000054800F087E
020_00407300000048AF
080_22A226C025200331
100_C812000000000205
"Vin = ZDM1H00AAMB005586"
"AE06B9E9"
"Bike = 8"
ZDM1H00AAMB005586
***reset annual***
021001
0250010000000000
service date : 250305
service interval
						Panigale V2 2021 Service reset not working
Re: Panigale V2 2021 Service reset not working
ok , but the licence is not recognized
cle.lic is unlocked ?
I checked and it was indeed locked. I unlocked it and tried again but still the same issue
This is the content of my new report file:
"File generated On 06.03.2025 09:32:17"
"Hardw = """
15 PIDS active founds
018_0002A000610648F5
019_96096000000308EF
080_1B4226C025200097
100_C812000001000F0B
020_0040730000004A95
300_2C98800E0DEFDDBF
174_0E800040A16B0B9E
178_F47F0000267F0B11
17C_FE7F01004A690B48
024_0000000000200162
190_8800000000000FC2
188_7FF7806B80AB4FDC
022_000000000003FF1A
18C_80037FFF0000000B
023_000000547F4B
"AE06B9E9"
"Bike = 8"
ZDM1H00AAMB005586
"Hardw = """
023_000000547F4B
"AE06B9E9"
"Bike = 8"
ZDM1H00AAMB005586
try to run melcodiag with admin rights then
Hi, I have tried starting it as an administrator. Still the same result. The debug report is still showing "not registered".
reset buttons are enabled ?
Oh yeah I forgot to mention that. If I connect to the bike in M3C Mode the buttons are enabled. If I connect in "any bike" mode, they are not enabled. However if I connect in M3C mode once and then connect in "any bike" mode, the buttons are still activated. Does that have something to do with the "not registered" part?
I can think of two things that are "different" compared to when it last worked:
- The version of MelcoDiag was 2.0.3.7 last year when I successfully reset the service
- Since it last worked, the ECU was flashed once but it is now back on the stock map
it's possible your vin has changed ?
