Panigale V4 2022 Annual Service/ Desmo not working
Re: Panigale V4 2022 Annual Service/ Desmo not working
have you tried to add +1 year to your pc clock to see if that is working better ?
milo
Post by milo »
I tried to set clock to 2026 and it didn't work.
joxi1000
Post by joxi1000 »
There must be something changed by Ducati from >=MY2022. When I browse the forum the problem concerns also other models, not only the Panigale.
mullesh
Post by mullesh »
Ran into a similar issue on my 2020 Scrambler. None of the annual resets seemed to work.
Here's what I did that caused it to work:
1) Change service date
2) Annual Service 1
3) Annual Service 2
Then when i looked over at my bike i noticed the date was flashing on the dash. Upon further inspection, I realized it was the date of the annual service. I was able to scroll through and set the date to 1 year in the future. Viola! Done.
Now, did I need to hit all of those buttons above? Im guessing no. But it worked and there seemed to be no ill effects. Hopefully this helps someone else out there.
