sorry if this is a contant issue
jase46
Post by jase46 »
received my jpdiag licence but not sure what to do with the cle.lic file.
the email says copy cle.lic file into jpdiag or melcodiag directory, im not sure what the directory is.
my bike is an 899 panigale with ternmi slip ons
Re: sorry if this is a contant issue
put the file in the same directory melcodiag is installed
jase46
Post by jase46 »
as in drag and drop the file?
sorry im not that clued up with this kind of thing
yes
check tutorials viewtopic.php?t=114
or how to register links viewtopic.php?t=5
jase46
Post by jase46 »
thank you much appreciated 8-)
jase46
Post by jase46 »
hi sorry to bother you again but does this look right as im not sure why theres alot of ecus showing.
last picture looks right , but the 1st one i think your elm was optimistic with so many ecu founds :lol:
jase46
Post by jase46 »
jpl250rs wrote: Thu Jan 08, 2026 6:29 pm last picture looks right , but the 1st one i think your elm was optimistic with so many ecu founds :lol:
Thanks for the reply, I did a gear reset as I’ve had the indicator saying it’s in first when actually in neutral from time to time And now I’m getting a flashing neutral and C, I’ve found how to re program the gears on YouTube but the bike won’t start to so I can do this procedure . Is there anything in the software to help with this issue?
why the bike cannot start ?
if the procedure need the engine to run , i'm affraid you have no choice
jase46
Post by jase46 »
jpl250rs wrote: Thu Jan 08, 2026 7:15 pm why the bike cannot start ?
After a search on ChatGPT once you’ve done a gear reset it locks out the starter for safety which is odd as you need to run the bike to re learn the gears.
